Digital Locks
12/5/18
Cab Guy Member
I have a job where the architect has specified CompX Stealthlock. However on a lot of the elevations, they have them required on multiple cabinets with two doors. These locks are already around $100 my cost and are only designed for one door. You're supposed to mount them to the gables, but I believe I can mount them on the stretcher or bottom and then use an elbow catch or one of the CompX Double Locks (DL-200). This would bring the cost way down on the instances with two doors. Does that make sense to anyone?
There are a couple three drawer banks that need all drawers to lock as well, requiring three locks. It's just going to be a very expensive elevation.
Are there any other digital lock systems that anyone has used?
I'm open to all ideas. But the important thing is that there needs to be one keypad that unlocks all cabinets.
http://stealthlock.com/
12/5/18       #2: Digital Locks ...
Alan F.
Digilock, Direct or Hafele
BeCode
Rick Hill
BeCode USA, Inc.
500 Boulder Ct. Suite B
Pleasanton, CA 94566
Office- 844.523.7871
Mobile- 925.321.1762
www.becodeusa.com
BeCode
12/5/18       #3: Digital Locks ...
Matt calnen
What about using an elbow catch or something similar on the door with out the lock? You could only open it when the lockable one is open.
12/5/18       #4: Digital Locks ...
Robert Duff  Member
Website: http://www.abettercloset.net
Use the CompX Double door catch they work great and less than $4 each
12/6/18       #5: Digital Locks ...
james e mcgrew Member
Watching this thread !
12/7/18       #6: Digital Locks ...
David R Sochar  Member
In our shop, the doors would close onto rabbets, and the paired doors get a rabbet also. Close the door with the protruding rabbet, and then the locking door. The negative rabbet on the locking door will retain the unlocked door. The locking door will lock to the cabinet.
12/7/18       #7: Digital Locks ...
Alan F.
Dav id,
The majority of Commercial casework is flush overlay, either laminate or veneer on composite core, so rabbets aren't practical in a standard square edge with 1 or 3mm banding. The CompX Double door catches work great for commercial.
We have done double door cabinets with a partition and a digital lock on each door because catches don't meet drug security rules in medical facilities.
If you use Digilocks you need to add programming keys and manager keys to the cost.
12/8/18       #8: Digital Locks ...
cabinetmaker
When using Digilocks don’t forget to ask about lead time and if you are going into existing space, they are going to require lot number and registation info.
It’s very important to work out your layout in the office or on a test as altering built boxes is very expensive and will cut into your profit very quickly
