Long dowel drills
1/11/21
Good morning.
Anyone have any idea where I can buy a 9mm dowel drill longer than 70mm?
1/11/21       #2: Long dowel drills ...
You can have it made.
1/11/21       #3: Long dowel drills ...
Dylan Bayliss  Member
we just quoted these 5/7 days to mfg
1/4" x 3” TWIST - 1/2” SHANK - 5” OAL
3/8" x 3” TWIST - 1/2” SHANK - 5” OAL
1/2" x 3” TWIST - 1/2” SHANK - 5” OAL
regards
db
1/11/21       #4: Long dowel drills ...
BH Davis  Member
Look for Aircraft drill bits. For example see the link below.
MSC Direct Aircraft Extension Drill Bits
1/12/21       #5: Long dowel drills ...
Matt J Krig Member
If you are not actually needing a deep boring bit and are looking for a long 70mm bit for an automatic doweling machine, there are bit holders/extenders that will allow you to use stock length bits. We had a similar issue on the horizontal drill on our Omal HBD and we bought the extender from SCM
1/12/21       #6: Long dowel drills ...
Thanks for the ideas.
We need a 52mm deep hole and are about 2mm short with a 70mm drill.
1/12/21       #7: Long dowel drills ...
jerry Member
Have you looked at McMaster Carr they have extended drill bits
https://www.mcmaster.com/drill-bits/length-class~extended-length/shank-siz
e~9mm/
4/21/21       #8: Long dowel drills ...
Joe
Reach out to Leitz. Their solid carbide dowel drills are the bees knees and last forever. Brian is a great resource for tooling.
View higher quality, full size image (1597 X 2268)
    • Biesse America
    • Better Vacuum Cups, Inc.
