2 pc MDF Doors. Caulk joints?
3/8/24
SteveL
I am really struggling with keeping 1pc MDF door flat. I've played with 2 pc doors some and like how they turn out flat however I can't get a good finish on them due to the joint between panel and frame. I've heard of people caulking these joints but haven't tried it.
I spray CV, is it even possible to spray something so hard over caulking. Won't it cause problems?
I'd appreciate hearing how others deal with this issue.
3/8/24       #2: 2 pc MDF Doors. Caulk joints? ...
Josh Koschak
While machining the frame, put a bevel on the inside edge to mimic eased edge shaper cutters. Intentionally create a small shadow reveal, then the finish wont bridge.
Set up your clearances so you can spray the two individually then press in your finished panel, a little bit of adhesive on the mating surface and you would be good to go.
