Subject: Re: 2 pc MDF Doors. Caulk joints?
3/8/24
SteveL
I am really struggling with keeping 1pc MDF door flat. I've played with 2 pc doors some and like how they turn out flat however I can't get a good finish on them due to the joint between panel and frame. I've heard of people caulking these joints but haven't tried it.
I spray CV, is it even possible to spray something so hard over caulking. Won't it cause problems?
I'd appreciate hearing how others deal with this issue.
3/8/24       #2: 2 pc MDF Doors. Caulk joints? ...
Josh Koschak
While machining the frame, put a bevel on the inside edge to mimic eased edge shaper cutters. Intentionally create a small shadow reveal, then the finish wont bridge.
Set up your clearances so you can spray the two individually then press in your finished panel, a little bit of adhesive on the mating surface and you would be good to go.
7/28/24       #3: 2 pc MDF Doors. Caulk joints? ...
Frank Garrido  Member
Website: http://www.cabinethero.com
I believe what you want is a solid looking finish with no gaps between the panel and Frame of the door. If this the case , caulking then sealing in the gap would not be a good step to take in the long run . That’s because the gap will experience movement as temperature and humidity fluctuates . Some shrinkage will occur and you will end up with the harder top coat CV cracking .
It’s much better to preserve the gap between the frame unless the frame was made from MDF and it was solidly glued down. Then there should be no movement and you could use a harder putty to fill like
Crawford Vinyl putty instead of caulking it (to soft of a material to put under CV ,
