Adjustable Z Axis Spindle Mount Holder for CNC Router -- 0 --
11/25
Website: http://www.qingonggroup.com
For multi heads wood CNC router, if you want to carve on different thickness workpiece at one time, dull-head spindle mount is hard to achieve this. Here is a helpful tool:
Model: spindle diameter 100mm/85mm/80mm/65mm
This mounting kit is an adjustable spindle holder for cnc router, especially multi heads cnc router. This adjustable spindle holder is also called manual tool calibration, great for multi heads cnc router processing on different thickness work piece. It is easy to adjust the spindle station by this adjust z axis spindle mount holder to keep the cutter bits on the surface of the work piece, then do the same job. Save time to adjust spindle heads height.
Also good for multiheads cnc router machine working on same thickness material, it is easy to adjust and keep all cutter bits at the same level.
Features:
Material: Stainless steel and Aluminium
Diameter: 100mm (85mm/80mm/65mm, optional)
View higher quality, full size image (610 X 437)
http://www.qingonggroup.com/products/112-Adjustable-Z-Axis-Spindle-Mount-Holder-for-CNC.html
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
