trying to find a sanding block
11/21/14
tiptop
Trying to find a double sided hand sanding block with velcro to attach sanding sheets. 4" x 2 1/2" by 1 1/2" thick. Does anyone have a lead?
11/21/14       #2: trying to find a sanding block ...
Chris
You could make one from a block of wood and Velcro from your local box store
11/21/14       #3: trying to find a sanding block ...
Adam West  Member
We sell a 3x4" yellow foam block work hook and loop on one side for our 3x4" film abrasives. It's 20mm thick.
11/28/14       #4: trying to find a sanding block ...
J.
Check the link below or this one:
http://mirka-online.com/91502-mirka-grip-faced-abranet-vacuum-block-2-3-4-x-7-1-2-
qty-1.html
load up with Mirka Abranet (or Abranet ACE if you're sanding hard -very hard hardwoods)
You'll not regret trying this.
I do a lot of curved work & I hand sand quite a lot, and of my constant experimenting with every latest-greatest abrasive out there, I have yet to find anything that outperforms the blocks & abrasives I just linked you
Mirka
