aluminum slatwall inserts -- 0 --
8/4
Who are good suppliers for the aluminum inserts for slatwall? We want to run the panels on the cnc and put the inserts in afterwards. Need a matching bit also.
8/4 #2: aluminum slatwall inserts ...
Depends on where you are at, I use Spacewall in Placentia Calif, they are also in Seattle, Georgia, Texas. I think they will sell the extrusions.
You should run the numbers on this though. They have a machine that gang cuts the slots which are diamond bits.
Spacewall
8/5 #3: aluminum slatwall inserts ...
It really is easier and far better to just purchase what you want.
8/5 #4: aluminum slatwall inserts ...
We do buy them when we need standard colors or finishes of slatwall.
This is where we need one or more sheets of a specific color - for example a job now is calling for 8 sheets with a specific Wilsonart metal laminate on the face. Are there suppliers in Northern California (we are in Sacramento) who will do that?
If not we do it ourselves so I figure better to get the panels laidup and run them on the cnc ourselves?
What do you experts think?
Thank you for the help!
8/5 #5: aluminum slatwall inserts ...
I used US SLATWALL and was well pleased on a 70 sheet custom order
8/5 #6: aluminum slatwall inserts ...
I don't know if they make custom slat wall anymore but Capitol is local to you.
Last time we bought extrusion I think we bought 5 or 10 thousand feet. I forget the extruder but they were out of LA. The extruders are usually at IWF.
Capitol Store Fixtures
8/5 #7: aluminum slatwall inserts ...
Space wall does custom and they are fast. i would think you could find a local supper with quick turn around, it is the store fixture industry afterall.
8/5 #8: aluminum slatwall inserts ...
Far better off buying from a slatwall manufacturer. Be careful if you decide to make your own. Not all inserts are the same, some won't fit in the profile from a supplier. Make sure you get a matching diamond bit if you are going to do it. Typical carbide bits go down hill pretty fast because they run hot in the tight T slot. You can get the inserts already in the panel or not. Best to not if you are going to cut the panel up. You also need a saw blade made for aluminum. IE, neg. hook.
9/3 #9: aluminum slatwall inserts ...
Thanks guys
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
