This thread got me curious how long it actually takes to build a cabinet door, so I made a little video. I know you said no shaker, but didn't feel like changing cutters or gluing up a panel for this. There's a hotlink at the bottom as well. I have no idea how to embed video on woodweb.
https://youtu.be/25GbUnlOHh4
As of 8:32 central, it's still uploading. YouTube is being a little slow for some reason.
Our process is as follows.
If raised panel, we start with the panels as you run out of clamp space with only 12' of clamp rack if you've got a bunch of doors, and you can be doing other stuff while glue is drying. We do joint everything for panels and we run our panels at 5/8" so they go through the planer twice, and through the widebelt twice before getting cut down to size and getting the profile machined in. We glue them up 1" long, and try to get around 1" oversized in width. We have a shaper dedicated to panel raising using a four wheel powerfeeder, and a continuous fence under the cutter. The cutter is a four wing carbide insert head from Dimensions in Tooling. I want to say it's spinning at 4500 rpm with a 17fpm feed rate.
I'd venture to guess that a raised panel would add another ten minutes to the construction of a door. Way more if it's just a single I'd bet. We started using a Dynabrade sander for the panel profile, it works alright. I'm confident there's no awesome way to sand those, but it's the best tactic I've used yet. The sanding is pretty minimal with that four wing, and the shaper is a tank that runs true so the cut is very nice.
For the door frame, we rip on the SLR an 1/8"+ oversized. Do our sticking cut first removing a 1/16", and then finish getting them to size with a straight cutter stacked underneath the sticking cutter. I shoot for the door being .040" oversized once assembled whether that is inset or overlay to allow sizing and/or fitment. If I want 2-1/4" sticking, we machine it at 2.270"
(If the job has paneled ends, we typically leave the stiles for those a 1/16" oversized so the panel is an 1/8" big. We pull the least straight material out for paneled ends before getting the rest of the door sticking down to size)
After the sticking is made we sort the material usually into five piles
1. Awesome
2. Good
3. Meh
4. Wow, not so good
5. Yikes.
Rails and stiles are cut on a pop up saw with a 10' Tigerstop. We do the largest stiles first out of the "awesome" stack and work our way through the material going down the list. With paneled drawer fronts, we generally work from the bottom of the pile up. If it's wonky, the dovetail drawer box will pull everything straight and it's no problem. Ideally on a decent sized batch you've got a few sticks of "good" and "meh" left over. If you don't and run short, there's usually some in the rack from the last run.
After cutting stiles and rails to length, the rails get coped. Currently we're using a pair of Powermatic 27 shapers for this task. With shaker style, you can use a square backer on both faces to prevent blow out. That doesn't work with anything other than a square profile, so we do left and right copers that are parked right next to one another for anything that has a profile. The long term plan is to replace those two hunks of garbage with a PMK coper, where you can do two single sided parts at once, and they act as a backer for one another. That should add some speed and take the operator out of the equation for the machining aspect. Some guys just can't cope it seems. Being that the other coper is right there, I don't think it adds much time moving to that one.
Assuming panels are ready to go doors are assembled. We use a Unique Machine brand peg style door clamp that I'm not real impressed with. Looking at replacing it this year with a JLT rotary clamp. The door in the video has some loose joints because that clamp just won't mash stuff together. To be fair, my fitment might be a twinge tight. Normally if I'm just doing a single like that, I'll pipe clamp it and walk away and do something else for 20 minutes while it sets up. In my old shop, the old compressor ran at a pretty high pressure, in here at the new shop, I don't go over 125psi, and that clamp's performance has just gotten worse because of it.
After assembly they go through the widebelt. We use a two head, with a combo head on the last head. One pass per face using 120g and 180g. It beats the snot out of the abrasives but it does leave a good scratch somehow.
Size/fit the doors on the edge sander.
Drill for hinges (label location in hinge cup if necessary)
If applicable do edge detail. (95% of what we do is inset, so no edge profile) If it's in a shaper, I'd add a solid minute per door for that process. Probably two minutes if doing it with a router.
Orbital the faces. I don't bother hitting the edge with the orbital.
Break the edges by hand.
Stretch wrap them up with like sized doors.
Send them to finisher. BYE DOORS, see you next week! miss you....
Obviously this stuff becomes way more efficient with the larger the quantity being built. Time wasted on little things like turning a machine on, or walking between stations gets spread out amongst 50 or a 100 doors and it get's pretty small per unit. Even the tracking in the video on the edge sander being a snot takes time that once spread out amongst a large number is nothing really.
I bet the door in this video were it in a batch and I weren't carrying a phone around shooting video, I could knock a couple minutes out of the build time. I doubt any more than that could be done though with my current setup.
