Adhesives
gluing solid wood together that will be bent
1/28/13
david boone
Website: http://cabinetsbydaves.com
What is the best type of glue to use if the wood will be planed to 1/4" thisk and slightly bent around a radius. Thanks
1/30/13       #2: gluing solid wood together that wil ...
I typically use plastic resin glue (weldwood), or urea formaldehyde (unibond 800). Second choice would be west systems epoxy.
PVA (yellow glue) can work but it is not ideal due to additional spring back and, possible long term creep resulting in failure. I have heard convincing arguments for and against with no consensus. I do choose to play it safe though because there are better glues for most applications.
1/30/13       #3: gluing solid wood together that wil ...
Most any glue will work for "Slight" curve as he is asking about. The trick on any of the glues is to get a uniform tight fit.
1/30/13       #4: gluing solid wood together that wil ...
uniform tight fit and adequate clamping pressure is "woodworking 101"
2/17/13       #5: gluing solid wood together that wil ...
William Olsen  Member
Website: williamolsendesigns.com
West Systems Is the best...
