Adhesives
EDGE BANDING A PAINTED EDGE
2/18/13
james777 Member
Hi everyone! Have somebody done what im about to do. I have some 18mm painted chipboard panels that i want to edge band it with PVC. Do i need to take off the paint?
2/18/13       #2: EDGE BANDING A PAINTED EDGE ...
cabinetmaker
Yes, you need a fresh edge.
cm
3/28/13       #3: EDGE BANDING A PAINTED EDGE ...
Gene Wengert-WoodDoc
You can leave the paint on, but when you glue, you will be gluing the paint to the other surface and not gluing the wood to the other surface. If the paint is well bonded to the wood, this wouldn't be a bad idea, but paint typically is not well bonded. So, remove the paint if you need a strong joint.
