Adhesives Forum
Wilsonart - Formica Adhesive switch
7/22/13
RJF Member
We are looking to change over from the Wilsonart 951 spray adhesive to the Formica F268.
Has anyone had any problems with the latter?
7/23/13       #3: Wilsonart - Formica Adhesive switch ...
Tracy Kling  Member
Website: http://WWW.MANCRAFTINDUSTRIES.COM
Just went off way to fast no open time.
10/2/13       #4: Wilsonart - Formica Adhesive switch ...
d315tm Member
This may be very late BUT. Are you switching from 950 to 268 because you need a "Green" glue? If so have you tried Wilsonart 1730? I would suggest if you are ever going to switch from a homogenized glue (950) to a non-homogenzied glue (268) that you test both glues side by side on identical material.
