Adhesives
casein glue
2/21/15
Drew H Nyman  Member
Can I use this glue when the temp is below 50 degrees? 40? I'm using a vacuum press
2/23/15       #2: casein glue ...
Ed
Website: http://www.qualityvak.com
I would not recommend it without using an electric blanket on the bag. Also, use the blanket to get your substrate and veneer up to 70 F prior to applying the glue.
2/24/15       #3: casein glue ...
Drew H Nyman  Member
Thank You, I didn't use the glue as I had a feeling it was too cold.
3/4/15       #4: casein glue ...
Very few glues are happy
2 less than 60! If you see any "chalking" things were too cold.
