Adhesives
Pressing Inside Curve
8/31/17
howard gorman
I have also posted this in the veneer section. I am having difficulty pressing an inside curve. Best way to describe the form I'm using is two hills and a valley(12" deep) and moderate radius . It's the valley that is failing. I am using a core of 3/8" wiggle board then two layers of veneer on each face. Unibond 800 at a slow set rate. So far I am not using a platen on the top, just the bag. Appreciate any suggestions you have since this is getting very frustrating and I'm running out of time.
8/31/17       #2: Pressing Inside Curve ...
The platen would be my answer. We just pressed a bunch of ribbon shapes that sound similar. no bag, top and bottom form, clamps. But the bag would be even better.
8/31/17       #3: Pressing Inside Curve ...
I suspect that when the vacuum bag engages the top of the convex sections friction builds so as not to allow the bag to get pulled to the bottom of the valley. I would suggest a top sheet of wiggly wood that you tape down in the valley before putting in the press/bag. To reduce friction try a piece of vapor barrier ontop of the top sheet.
As you build vacuum stop the pump and massage the bag into the valley then pull down more until you get what you want.
Do this dry to see if you are having success without ruining anything.
8/31/17       #4: Pressing Inside Curve ...
Keith
I like to use epoxy for this kind of work because it is as slick as grease and allows the parts to slip as needed.
9/7/17       #5: Pressing Inside Curve ...
Like wise go with epoxy it gives you more time before it gets sticky. Most importantly make the bag extra big. Even if you have to use mastic tape to glue it together. The bag can never be too big. But it can definitely be too small. Its easy to get bridging where there is either no or too little compaction between your hills.
When we do complex composite shapes we always make the bags bigger.
This can be the downside of using tube or envelop style bags versus custom mastic bags.
9/16/17       #7: Pressing Inside Curve ...
Greg Aanes  Member
Website: chairsnw.com
Ditto on pressure on the inside curve. Cut a chunk of styrofoam to use as a a platen inside the baf to fit the curve. It will have enough flex to fill the valley. And finally something to do with those neat blocks of styrofoam that come with packages. Need bigger? Build up your block with spray adhesive such as 3m sup 70
