Adhesives
edge tape adhesive - chemically sensitive client
9/5/18
Richard Goodman  Member
Website: lagunabamboo.com
I have a client that is chemically sensitive and I was wondering if anyone could advise me as to what I should do about the glue that is used on the edge tape ? I was going to outsource the edgebanding to another shop that uses Dorus KS-217 adhesive. Any advise on how I should handle this would be appreciated.
9/8/18       #2: edge tape adhesive - chemically sen ...
Bryan "doc" Henderson  Member
Richard. I would try to get a little history of this sensitivity. I am a Internal med/pediatric doc. In the ER for 17 years. Some people have true allergy but to fairly specific things. Some think anything that smells funny is causing a reaction. Most reaction would be to contact the cement directly or the off gas ect. during the curing. After that, most things should be inert. you could try a test sample for them to have to be sure. If they name a hundred different things that they have had trouble with, then good luck.
9/13/18       #3: edge tape adhesive - chemically sen ...
Thanks Bryan
9/17/18       #4: edge tape adhesive - chemically sen ...
Mike Member
Website: http://builtcustomcarpentry.houzz.com
I think you could easily do hot melt, which I think is PVA based. Not too many harsh chemical in that and no off gassing. In terms of allergies, I honestly wouldn't be too concerned myself unless you are using formaldehyde or other off gassing adhesives. Contact dermatitis from a miniscule glue line should be a very low risk especially if you have a finish on top of it. Like the doc said, dermatitis is very specific and being sensitive to chemical in my experience has been mostly due to smells as things cure etc.
