Adhesives
Combi Core Plywood
2/21/19
Andy Schermerhorn Member
Website: http://precisionbuiltusa.com
I have a situation where I need to veneer 1" thick panels for some case work. I know that normally most people would use MDF for such a thing. I am just looking for a possible alternative not to debate over mdf. I tried to buy 1" combi core (1/2" or 3/4" mdf with layers of 1/8" poplar material on either side to make thickness) for the substrate, but it is not available in my area. Has anyone made their own combi core material before, and what adhesive did you use?
The panels will be wrapped with a hardwood edging and then veneered, cut to size, and machined for joinery. The largest panels will be 60"l x 22"d
2/21/19       #3: Combi Core Plywood ...
Joseph
1" MDO.
2/26/19       #4: Combi Core Plywood ...
John Costin
Ewww, I hate veneering on MDO! Andy, are you not in Atlantic Plywood's service area? If you are, ask them for Pluma HDF. It is Italian Poplar plywood with 2mm HDF skins, and it is available in 1" thickness. Another alternative is to get a good quality 3/4" veneer core and press on your own 1/8" HDF skins.
John Costin
Veneer Services Unlimited
Custom Veneered Components for the Woodworking Industry
(207)459-7221
vsu@gwi.net
7/30/19       #5: Combi Core Plywood ...
KlausHe Member
Website: http://www.china-mingtai-al.com
8011 aluminum foil is used of medicine sealing, Mingtai can produce 8011 aluminum foil for medicine sealing, we are looking for your inquiry!
View higher quality, full size image (750 X 420)
