Adhesives
punky wood
1/8/20
ken Member
I have a maple slab about 48" diameter that I have slab milled to 2 1/2" thick. After milling I noticed some "punky" or rotten / soft areas had appeared that were not there previously or un-noticed. Does anyone know how to possibly repair or "stiffen" these areas so that I can continue on finishing this slab to a table top. I can not find any forums or discussions here about epoxy resins or anything that might relate to this. Thanks
1/8/20       #2: punky wood ...
perley bowen
The wood turners use thin CA glue.
Perley
1/9/20       #3: punky wood ...
ken
what is the thinning agent and do I mix the sawdust in with it or just apply it as is? Thanks for your response.
1/9/20       #4: punky wood ...
Jessica  Member
Website: finecraftsmanlumber.com
I've never used it before myself, but I've heard of people using a stabilizing resin. I think the way it works is the resin is very thin and the wood absorbs it, therefore giving the rotten wood more structural integrity. Here's of video of Matt Cremona using it.
https://www.youtube.com/watch?v=gmJZlduLYHI
1/9/20       #5: punky wood ...
perley bowen
You can add saw dust or just plain. Depending if you need to fill gaps.
Perley
1/9/20       #6: punky wood ...
ken
thanks. all help is most appreciated.
1/10/20       #7: punky wood ...
What about Smiths CPES or any of the penetrating epoxies from West or TotalBoat. All should work but are going to foul any future finishing if it requires stain.
1/11/20       #8: punky wood ...
ken
it will not require stain but will require a poly finish and I want it to look natural and not patched or artificial. Will your suggestion work? thanks ahead. Ken
1/12/20       #9: punky wood ...
I would think if you ran the penetrating epoxy on the soft area and then perhaps just hit the entire thing with the same you'd be solid. Perhaps do a test on a drop/scrap or the back side.
1/12/20       #10: punky wood ...
ken
thanks for the reply. will check out the product a little more.
1/26/20       #11: punky wood ...
Jerimiah Keller Member
I also recommend thin CA glue.
10/30/20       #12: punky wood ...
Marvin Lee  Member
Website: https://www.heatsign.com/
Saw dust and CA glue both can be effective to fill the gap.
    • CP Adhesives
    • Lockdowel, Inc.
