Adhesives
glue pot temp roller temp
3/13/20
sean Member
Website: http://www.modularsystems.net
Practicing with some 3mm edge banding.
Temp 200 on the glue pot and 190 on the roller. It dries crazy fast and bonds solid.
If I turn the temp up a little more will it smooth it out better? scm k1000 unit.
3/13/20       #2: glue pot temp roller temp ...
Tyler
depends on the glue you're using and what temperature limits it has
3/13/20       #3: glue pot temp roller temp ...
Rob Young  Member
Website: nutekmachinery.com
Each glue has a range of feed speeds and a range of temperatures recommended for best results. There are factors that can affect these numbers such as ambient and board temperature. The goal is for the glue to be at a specific temperature when the panel reaches the first pressure roller. The time that the glue has been applied to the board until the edge makes contact at the first pressure roller is known as "open time" If you have the temperature set correctly to match the feed rate of the belt the glue will be at just the right consistency for the glue to squeeze out on the top and bottom without being so hot that the edge material doesn't adhere well enough to prevent de-lamination as the panel travels through your machine. For example if you are given a temperature range of 190 to 210 degrees Celsius with a feed rate between 10 and 30 meters a the glue temperature would be approximately as follows. The slower the feed belt the higher the temperature and the faster the feed belt the lower the application temperature. 10 meter feed speed would equal 210 degrees Celsius. 30 meter feed speed would equal 190 degrees Celsius. The slower the track speed the higher the glue temperature the faster the track speed the lower the glue temperature.
3/14/20       #4: glue pot temp roller temp ...
Mark
I have a different machine, but my temps are the opposite of yours.
My glue pot is 190 and the glue roller is 200.
I don't know if that's enough difference to cool the glue before application, but I thought I would share that with you.
Mark
3/14/20       #5: glue pot temp roller temp ...
sean Member
Wow thank you for the information. I have been trying this glue from Canplast 820010 45 CLEAR. We pretty much only use 3mm edgeband on pb board. 18mm I tried 12mm but it ended up a mess. I am learning. I really need to find someone to train us on the machine. I really appreciate the help
    • CP Adhesives
    • Lockdowel, Inc.
