Adhesives
Dying pva
4/24/20
Gabe O Member
I would to color pva adhesive a dark brown-black color for reclaimed wood laminations. I am using Franklin 405 and titebond 2. Would adding dye to the glue effect curing or strength?
4/24/20       #2: Dying pva ...
Jeff Pitcher
You can dye PVA with no problem. There are a number of appropriate dyes at www.veneersupplies.com
4/25/20       #3: Dying pva ...
david zaret Member
i dye PVA all the time with transtint. works perfectly.
1/15/21       #4: Dying pva ...
Joseph Member
Mix some of your newly acquired sawdust with wood glue, and be sure to have more wood than glue in your mixture. Apply a small amount of your glue mixture to the areas that will join together. When you put the parts together, either find a clamp, or in my case, use gravity to set the pieces in place.
    • CP Adhesives
