Adhesives
Glue for veneer on Venetian blinds
8/11/20
Anton Member
Hi
I need to glue veneer to Venetian blinds slats. Slats are made from basswood.
At the window we have big moisture and temperature gradient. Please help wit the glue choice
8/12/20       #2: Glue for veneer on Venetian blinds ...
Titebond 2 will give you a strong stable bond regardless of the heat and humidity.
9/5/20       #3: Glue for veneer on Venetian blinds ...
D Brown
The slats most likely have a finish on them either paint or a clear coat you will need to adhere to whatever you are gluing to with the proper material and method.
9/6/20       #4: Glue for veneer on Venetian blinds ...
rescraft
How do you make a Venetian blind?
Stick your finger in his eye. Carry on........
    • CP Adhesives
