Adhesives
casement window weatherstip
8/18/20
Mike Glosta Member
I'm about to begin a refurbish of seven Andersen wood casement windows. It is the weatherstrip which concerns me. The windows are early stage, '32 - '75 as best as I can tell, all wood. I know where the frame weatherstrips are which can be easily replaced but am unsure if a rubber strip goes around the entire sash because there is a 3/16ths" approx.groove around all 4 sides. Andersen was no help and I can't find any data or specs for these old windows. Does anyone have a suggestion(s)? Thanks,
Mike Glosta
8/24/20       #2: casement window weatherstip ...
Chris @rangate Member
Website: https://rangate.com
Hi Mike, would you say the newer EPDM or TPE type gasket may do? 3/16" would be a tight fit for a 5mm. What's the length and gap size? Maybe a hardware/gasket supplier can help you with a drawn up diagram of the frame and a picture of the existing shape of the gasket. Maybe I can help further via email. Cheers.
    • Supergrit Abrasives
    • CP Adhesives
