Adhesives
Titebond on teak siding
12/15/21
Kim Thich Member
I am managing a job on Kauai where we are installing teak siding . The siding is 9/16” x 5” face t&g from Indoteak. It is an engineered product that uses solid teak as the crossband sub layers. It is prefinished with Rubio monocoat on the face and back sealed with a water base sealer . It is going on top of sheathing that has 3/16” furring strips every 8”.
We are mitering corners and miter returning into window and door jambs. We have a floating 1/8” spline in jamb edges to connect to slotted mitered returns that are 3/4” to 1-1/2” wide.
We are using West System, fast cure with microfiber. We are wiping glue surfaces with Acetone prior to gluing. We are blue taping glued miters and also pin tacking with 23g ss headless pin nails.
We are removing blue tape on miters within 1 hour to wipe off any glue residue with acetone and changing to clean rags frequently.
WONDERING IF WE CAN USE TITEBOND III instead of epoxy. Concidering all install location factors like: 9’ tall walls, deep overhangs, weather that can be sweltering hot to windy/wet and any factors above. West System is bomb proof but it is so time consuming and we need to be careful with not getting glue residue on exposed surfaces.
If we went with TBIII we would still wipe glue surfaces with acetone.
Like to get some solid feedback.
12/15/21       #2: Titebond on teak siding ...
Matt Calnen
I too love the West System 105 epoxy. As a Michigander, it’s better brand than a Ford anyday. I have been using the G5, which is their 5 minute epoxy. Don’t be fooled by the 5 minute label, it’s strong $hit. In reading the literature on the product, it may not fair well in overly wet environments. Not sure how much moisture your joints will see, but titty bond 3 never impressed me in an application that needed strong holding power. I believe another woodweber states that it loses substantial strength after it gets above 130 degrees. My front door, which is a mahogany, gets very hot on the outside during the late afternoon when it get full exposure the sun. Never would have thought it would get as hot as it does, and I’m in northern Michigan. Good thing I used the 105 west system.
12/16/21       #3: Titebond on teak siding ...
David Sochar has commented that TB III adhesion strength degrades with heat. Another problem that I have seen is PVA will swell when coated with oil finish. You end up with a small ridge at the glue line. I am not sure if that would happen with Rubio but it does with tung oil and other true oils.
Could you make test joints and run them through cycles of heat and wet?
12/16/21       #4: Titebond on teak siding ...
Website: https://www.acornwoodworks.com
What I learned about TBIII is that is loses its strength - its grip - as temperatures increase. At 180 degrees, it loses about half it strength. We have had very dark doors register a surface temp of 200 degrees just from solar exposure. We had about 12 projects out in the world with panels glued for width that came apart or threatened same.
If you wish to use TBIII, I would call the tech department at Franklin glue and use the temps you think this siding may experience. They were very candid with me.
As for using the epoxy, I once had a boss that would at the precise moment say "This is why we call it work, and this is why we pay you to do it!" I have been known to repeat that rough bit of managerial wisdom. I think I'd stick with the epoxy.
12/16/21       #5: Titebond on teak siding ...
Kim Thich Member
Yes, it’s is work. I don’t want any call backs ,so probably staying with epoxy.
12/25/21       #6: Titebond on teak siding ...
You are doing everything as good as it can be done. Why do you want to switch to TB3. Epoxy is the standard for glueing teak. Over the decades we settled on TB1 for interior and epoxy for exterior. Every other product that's exterior rated negatives.
There are usually 3 reasons why people don't use/like epoxy. Cost, lack of experience, time to mix/waste.
The wood cost alone means that cost should not be an issue. You've got the experience and time to mix is irrelevant in almost every project.
You can improve your epoxy usage by using vinegar for general cleanup. Iso alcohol(rubbing) is the best solvent for epoxy. Not denatured alcohol or acetone.
I would encourage you to try MAS epoxy. They have a product called FLAG resin. It's thick enough that you don't have to thicken it for woodworking. It's also a modern 2:1 non-blushing system that doesn't cause contamination issues.
West System is good stuff(I've used 100's of gallons) but the viscosity is always a problem. 5:1 mixing is a bit annoying as well. It's available everywhere so that's a plus.
12/25/21       #7: Titebond on teak siding ...
Kim Thich Member
Yes, We are sticking with epoxy . Just thought to ask if there were other options.
We had a learning curve at the start . Guys were not careful with epoxy residue from joints and handling material . So they have to use fine wire brush to rid epoxy from miter joints and surface areas. I will try the green scotch brite attachments for dremel drill.
I will use iso alcohol , acetone is what we been using.
12/27/21       #8: Titebond on teak siding ...
Fred Frehner
Website: http://www.rivercity.ca
Hi Kim,
We started to use a product by Loctite.https://www.richelieu.com/ca/en/category/glues-silicones-and-caulking/cons
truction-glues-and-adhesives/polyurethane-glues/loctite-glue-ur-series/1209594
Mostly on exterior door components and arch laminations including Accoya, so far we have no failures. The attached web page does not list, but it but it is available in 5 gal, with 60 and 70 min. open times.
Its messy to work with and hard to clean. It stands up to heat well and is water proof.
Not sure if it is better than the west system epoxy. One plus is you don't have to mix it.
12/27/21       #9: Titebond on teak siding ...
Fred Frehner
https://www.richelieu.com/documents/docsGr/120/959/4/1209594/1466670.pd
Not sure if the link works in the original email. hope this works better.
1/23/22       #10: Titebond on teak siding ...
Kevin Dunphy
Website: http://www.kdunphy.com/
TITEBOND III seen it first hand it gets soft in the heat.
In the second picture, those are all miters? did you biscuit or spline that looks like something that could open up
Those small mitres wouldn't take much to hold the mitres. I used one years ago a two gun cartridge with no mixing especially on site
Expoxy is epoxy you are well covered no much pounding rain.
Just curious do you put a clear coat after and do you caulk the seams
https://www.amazon.ca/Manual-Epoxy-Applicator-Gun-6-75/dp/B07Q8FVTXZ?th=1
2/6/22       #11: Titebond on teak siding ...
Kevin Dunphy
Curious why you don't answer the question I asked
2/6/22       #12: Titebond on teak siding ...
Kim Thich Member
Kevin,
We are staying the course with west system epoxy. All siding is prefinished with Rubio Monocoat from supplier. We backsealed with water based sealer from HD. All walls are furred out 3/16” every 8” for airflow . T&G is glued in with Titebond 3 ( probably switch over to water based clear caulking ) epoxied miters at corners and short returns to doors/windows are pinned with 23g ss to hold position . Stretched blue tape is used as ‘clamp’ at miters.
The most important part through out is wiping, wiping , wiping ….all epoxy residue on visible surfaces with acetone as solvent. Always using clean rags , otherwise dissolved epoxy residue gets spread around more.
No need for mechanical joints like splines etc at miters , boards are nailed off to wall in close proximity to glued miters. We are busting original budget for siding , but I convinced client how it will look awesome when entire house is sided… added another 100k plus . Don’t need to sweat it out so much now. Apologies for not replying ,hope this suffices.
2/6/22       #13: Titebond on teak siding ...
Kim Thich Member
Also, we will soften sharp miters and tough up with more Rubio Monocoat
2/8/22       #14: Titebond on teak siding ...
Kevin Dunphy
Thanks for the update, looks easy at first glance it looks easy but it's tricky.It looks, killer
    • CP Adhesives
    • Lockdowel, Inc.
