Adhesives
Loose p-lam
12/23/22
Just wondering what your adhesive of choice is for loose plastic laminate repairs. Every once in awhile a front edge or an end piece edge will come loose.
I usually use water base adhesive, something like 3M for building with Plam, I use it for repairs as well, but with so many newer adhesives thought maybe something as good and quicker might be available?
12/26/22       #2: Loose p-lam ...
Mark B
Im thinking the WB is your problem. Loose spots (rare for us) if they happen are dealt with heat. Heat the laminate and roll it back down til it cools. This wont work woth water base. WB in my experience has very strict application requirements and is much harder to deal with in general forget about in a repair.
4/13/23       #3: Loose p-lam ...
Chippy1987 Member
Could you try liquid contact cement or a polyfix glue?
    • CP Adhesives
    • Lockdowel, Inc.
