Adhesives
Plastic resin adhesive ideal temp
5/21/23
Dave Edgerton  Member
We are using cp-0503 adhesive for some solid wood projects. We want to put them in a hot box to cure after clamping. What is an ideal temperature that i am shooting for? 30C? or hotter?
5/21/23       #2: Plastic resin adhesive ideal temp ...
I have pressed PPR at 100°C with a cycle time of 5 minutes. The temperature did not compromise the glue joint. At 30°C you will have to test your joints. You have to allow for the components to come up to temperature - the larger the components the slower the heating. So I would go as high as practical in the hot box. You might also consider pre-heating some components if the assembly is not complex.
