Adhesives
Paper-laminated foam board to wood?
6/24/23
Lando
Seems many things would work for this, but I have no experience adhering anything to foam board so I thought I'd better get some input. Do note the paper coating is matte, not glossy/clay-coated.
Thanks in advance for your advice!
6/27/23       #2: Paper-laminated foam board to wood? ...
Dave Edgerton  Member
Pva
2/14/24       #3: Paper-laminated foam board to wood? ...
Ben Smith  Member
Website: loxleyarts.com
Check the water content if PVA/waterbased adhesive doesn't affect the foamboard paper covering. If it does a resin-based or heat set adhesive might be best
2/15/24       #4: Paper-laminated foam board to wood? ...
Angel17 Member
Coat the wood with foam insulation adhesive, then press the insulation lightly against the wood. Do not compress it, though. Wait until the adhesive begins to bond with the insulation before pressing it firmly. If the temperature is between 40 and 60 F, this takes 6 to 10 minutes.
