Adhesives
Bubbles
8/17/23
Jaykay Member
Hi,
How to make Polyviny Acetate based woodwork adhesive bubble free during manufacturing process.
3/18/24       #3: Bubbles ...
Hi Member
Website: https://virmer.com/
Hi,
You should mix the adhesive components for a minimum of 3 minutes at a speed of 1000 RPM, and place the mixed adhesive in a vacuum chamber and apply a vacuum of -0.9 bar (absolute pressure) for 5 minutes to remove trapped air effectively. As for the temperature, I would reccomend you to maintain the adhesive and wood surfaces at a temperature of 64-77°F during application to ensure optimal viscosity and prevent rapid evaporation.
9/24/24       #4: Bubbles ...
neelaadri trueframe Member
Website: https://www.trueframe.in/upvc-french-doors-in-bang...
Im facing the same issue.
5/22/26       #5: Bubbles ...
Quint Member
The vacuum degassing step is what most small shops skip and then wonder why they get bubbles in their bonds. Mixing speed matters too — too fast actually introduces more air than it removes. Temperature control during application is underrated as well, cold adhesive gets thick and traps air pockets way more easily than adhesive kept closer to room temperature.
