Adhesives
Is wood glue or gorilla glue better for gluing wood?
6/11/24
Kustom Beams  Member
Website: https://kustombeams.com
If I'm building a wooden bookshelf for my living room, which adhesive should I use to ensure the joints are strong and durable? I've heard mixed reviews about both types of glue and want to make sure my project lasts. Can you provide insights based on experiences with these adhesives in similar woodworking projects?
6/11/24       #2: Is wood glue or gorilla glue better ...
As stated many times, all professional wood glues, when used properly, can provide joints that are stronger than the wood.
Keep in mind that maximum surface area also contributes greatly. Mortise and tenon is better than a butt joint because of the greatly increased surface area.
Many glue failures are not a glue failure as much as they are a joinery failure.
6/13/24       #3: Is wood glue or gorilla glue better ...
Jamie Hughes
I prefer to go with a wood glue over the polyurethane type glue simply because of clean up being so much easier. If this bookcase is going to stay inside, you could use elmers white glue (remember 1st grade) and you would be amazed at how strong it is with good clamping. As stated above, good joinery is paramount when it comes to longevity of a piece.
6/17/24       #4: Is wood glue or gorilla glue better ...
Leo G
The only time I think about using polyurethane glue is when I need waterproof joinery. I might use it for a panel on an exterior door.
It's messy to use, it expands and foams and can get everywhere. The life in the bottle is shorter than yellow PVA.
It has it's use. But for normal use I prefer PVA.
8/8/24       #5: Is wood glue or gorilla glue better ...
The MW Studio  Member
Website: themillworkstudio.com
Wood glue. Gorilla glue is best with with oily woods such as teak.
9/5/24       #6: Is wood glue or gorilla glue better ...
Jake Member
For building a wooden bookshelf, regular wood glue is the better choice compared to Gorilla Glue
9/25/24       #8: Is wood glue or gorilla glue better ...
khushi sharma Member
Website: https://omegaelectricalss.com/
PVA or polyvinyl acetate generally known as wood glue is more appropriate for woodworking because it is formulated to be used with wood and produces a strong, flexible bond when dried. Gorilla Glue, a polyurethane adhesive, is stronger than epoxy adhesives and moreover resistant to water, but is messier when it comes to wood joints as it expands as it dries. In fact, for all the woodworking projects, most people recommend the use of a wood glue.
10/3/24       #10: Is wood glue or gorilla glue better ...
Al Holmes Member
For building a wooden bookshelf, PVA glue (polyvinyl acetate) is often recommended for its strong bond and ease of use. It's specifically designed for woodworking, dries clear, and is easy to clean up with water. Titebond III, a popular PVA option, is waterproof and has a longer open time, allowing you to adjust pieces as needed.
Epoxy is another excellent choice for joints that require extra strength or are exposed to moisture. It creates a very strong bond and can fill gaps well, making it ideal for challenging joints.
In general, PVA glue is sufficient for most bookshelf projects and offers a great balance of strength, convenience, and durability. If you’re looking for added moisture resistance or are working with complex joints, consider using epoxy. Both adhesives have proven reliable in similar woodworking projects, so your choice may depend on your specific needs and preferences.
    • CP Adhesives
    • Lockdowel, Inc.
