Adhesives
Custom tinted edgebanding glue
1/12/25
Bozzy Member
We have a large project coming up where we are using a high gloss gray hpl for doors with 1mm PVC tape. When we use Eva white glue, we get a very obvious white line and when we use translucent PO glue, we get a black like/mouse teeth. When we use 0.5mm tape and white glue, the white line is not visible.
I guess I have two questions, why is the glue line thinner with 0.5mm tape vs 1mm tape and has anyone ever used custom tinted edgebanding glue?
Lastly, our edgebander can run PUR, but have not tried it yet. Would the PUR glue line be that much thinner to make the joint disappear from 6" away?
1/15/25       #2: Custom tinted edgebanding glue ...
Jeff Bergstrom
A PUR glue line is 6X thinner than an EVA glue line. It doesn't have the initial tack strength of EVA so you have to let it cure for 24 hours for maximum strength. We use Jowat 608.00 with good results
1/18/25       #3: Custom tinted edgebanding glue ...
lary
DORUS KS 351
1/23/25       #4: Custom tinted edgebanding glue ...
Joe Knobbe
What edgebander / glue application method. I see almost invisible glue lines with PO glue. Try dialing back the amount of glue applied as far as you can.
1/23/25       #5: Custom tinted edgebanding glue ...
Bozzy Member
Stefani KD and glue is servo controlled. Any less glue and the tape is falling off
