Adhesives
Glue for PVC Edgeband manual application, 90-degree corner piecut cabinets
1/14/25
Matt Member
So for situations where you need to use a custom color edgeband that you cannot get in an iron-on option, how are you all gluing on the edgeband?
In my situation it's a 90 degree pie-cut cabinet but could be anything similar.
I'm aware that you can use a high quality contact spray but I've always found those results lackluster, it's difficult to get a glue pattern that doesn't telegraph through the edgeband.
I just tried to use a PUR hotmelt glue gun on this and surprisingly the PVC doesn't stick to the PUR worth a flip, which I was really surprised at since PUR is supposed to hold better than the EVA stuff most of us use in our banders.
My last ditch effort at a top notch product is going to be using P-Lam that matches, since at least I know it will have some rigidity and won't telegraph the spray glue line.
1/20/25       #2: Glue for PVC Edgeband manual applic ...
mick folan
I cut these shelves an the cnc and intentionally leave the radius in the corner. we have an old Griggio edgebander but it's of Chinese origin that applies the glue to the edging, not the board.
I double apply hot glue to the banding and apply with a heat gun and trim by hand afterwards.
1/28/25       #3: Glue for PVC Edgeband manual applic ...
Bruce H
We use double tape from Fast Cap. I am not exactly thrilled but it seems to work.
3/11/25       #4: Glue for PVC Edgeband manual applic ...
RonaldStone
I tried the above methods but they didn't work for long.
