Adhesives
Aluminum foil stick to XPS foamboard
4/7/25
M. Imran Aslam Member
Website: http://diamondfoam.com
Can someone direct me to the Adhesive I can USe to stick Aluminum to XPS foamboard? I know PU adhesive will do it, but which one should I look for?
4/27/25       #2: Aluminum foil stick to XPS foamboar ...
Angelan Member
You can use a construction adhesive like Loctite PL300 or a similar foamboard adhesive, which is specifically designed to bond materials like XPS foam and aluminum. Ensure it's suitable for both surfaces and apply it according to the manufacturer's instructions for best results. Always test a small area first to confirm compatibility.
