Adhesives
Raw wood to prefin maple ply
9/19/12
Chris
Does melamine glue work?
I am building a vaNity that hangs on a wall with vessel sink. Cab is 3/4" frameless. Back will be 3/4" too. An architect friend of mine suggested using a strip of hardwood 3 x .75" running along top inside GLUED AND SCREWED to back and top. I really don't want to strip the finish off that part of inside of cab but will if there is no glue strong enough to hold on a factory finished ply product. I'm open to suggestions if there is another way than my architect friend mentioned.
9/21/12       #2: Raw wood to prefin maple ply ...
I am not sure what the point of the strip is, and why you couldn't just screw it in.
It is very difficult to get anything to adhere well to pre finished plywood. You could try melamine glue, PUR, etc... and it might stick initially, but I wouldn't expect it to last or hold up.
Even autobody trim tape which is made to stick to glass smooth automotive finishes won't stay attached for long which surprised me.
9/23/12       #3: Raw wood to prefin maple ply ...
Chris
The reason for the strip is to have a doubly strong connection from cab back to top.
Screws alone are probably enough but I'm of the worrying tribe that always overbuilds in order to sleep well at night.
5/27/25       #4: Raw wood to prefin maple ply ...
Johnathan Rendon
Melamine glue can work, but it's not always the best option for bonding to factory-finished plywood, especially with slick melamine or UV-cured surfaces. Most traditional wood glues (like Titebond II or III) don’t adhere well to non-porous finishes unless the finish is scuffed or removed. So in short: Yes, melamine glue can work, but it’s not ideal on finished surfaces without prep. Either scuff the area or go with a strong construction adhesive and rely more on screws or cleats for structural support.
