Subject: Re: Wainscoting Panels
Wainscoting Panels
3/14/14
Josh Koschak Member
I currently build my wainscoting panels using my shaper with a 1/4" width dado cutter and my router with 1/2" long tenon cutter. My question is, will it be adequate to build the frame with butt joints and my Festool domino xl, dry fit, cut the groove in frame, disassemble, put in panels, glue butt joints and dominos in, and clamp assembly? I feel I could build the same pieces in half the time using this method, and the flex of the panel for transport and finishing would be drastically reduced. I have been building and prefinishing these in the shop before bringing to install. The stairway panels are next up and are just over 16' long. The picture attached is a ceiling panel that measured 204" x 54". Any input is greatly appreciated.
View higher quality, full size image (1280 X 720)
View higher quality, full size image (720 X 1280)
3/14/14       #3: Wainscoting Panels ...
Dominos would be stronger than the stub tenon. Either are adequate. Since the thing is going to be fastened to a wall, biscuits would be adequate. That type of wainscotting is often done on site by finish carpenters with a biscuit joiner. I've personally done a couple of large rooms that way.
You could also use pocket screws.
3/15/14       #4: Wainscoting Panels ...
I am a fan of mortise and tenon since it seems to work best over time, and is the quickest way for our shop to do the joining. The tenons are about 1/4 x 3/4 long in 3/4" stock, and usually are fit into plows in the stile stock. This allows for shifting positions as needed, as well as knocked down sections for field assembly.
The tenon joints, with properly glued shoulders, do not open over time or crack the finish like other methods are prone to do. I have 40 year old jobs that still look great, but have seen pocket screwed joints open in months.
3/15/14       #5: Wainscoting Panels ...
I think the Dominos would be fine. Better than stub tenons.
    Doucet Machinery
