Subject: Re: laminating mdf for strength
1/23/16
Dave Boykin  Member
Website: http://www.boykinpearce.com
Does laminating three 1/4" sheets of mdf give one a panel that is stronger than a single sheet of 3/4" mdf? My understanding is that the glue lines in a laminated panel would make it more rigid.
Any thoughts?
1/23/16       #3: laminating mdf for strength ...
That's a lot of fooling around for little if any gain. You could just go to high density fiber board in stead of the medium density. Very strong stuff.
1/24/16       #4: laminating mdf for strength ...
james mcgrew Member
Looking at The Boykin website my firsat though would be this question is not alien to you.... why are you asking this ?
1/26/16       #5: laminating mdf for strength ...
MDF has a hard time supporting itself over a span, no matter how thick. Try running the numbers on the Sagulator.
We often make torsion boxes with 1/4" MDF faces, whatever thickness we want, that are far stronger than anything solid.
The shelves in the photo supported a 250 lbs office employee, with a 10' span, with less than 1/16" sag, before they were supported by the back.
Sagulator
2/18/16       #6: laminating mdf for strength ...
Chris
David R Sochar, I would love to the see design for the torsion boxes you've made they look great. If you don't mind sharing...Chris
