Subject: Re: Touch latch on curved door
6/14/16
Gavin
Hi all ,
Has anyone got a suggestion to putting a touch latch on a curved door? I have run into this before where the arc of the door interferes with the touch latch working . Any suggestions would be greatly appreciated .
Thanks!
6/15/16       #2: Touch latch on curved door ...
james mcgrew Member
Mortise the needed receiver area flat to match
6/23/16       #3: Touch latch on curved door ...
John Bishop  Member
Website: selectwoodworking.net
Salice makes a push to open hinge system that is very nice and we use it on curved stuff. It has a reciever that is a mail/female deal. It has nice adjustments and it very clean looking.
good luck
DJB
6/23/16       #4: Touch latch on curved door ...
Gavin
John,
Thank you, Do you happen to remember the name of it . Or have a picture? I have been talking with Salice, by my local dealer seems to send me the wrong stuff
6/24/16       #5: Touch latch on curved door ...
PM Dennis Bean, he is a Salice Rep.
He posted here
6/24/16       #6: Touch latch on curved door ...
Keith Newton
I'm pretty sure I've used these little mini touch latches on curves before. If you mount it horizontal in the bottom corner, it will be out of the way.
They are easier to locate if you have double doors, allowing you to reach around behind while one is open. If it is for a single door, the easiest way I've found, is to locate the mechanism first, then stick the keeper onto a piece of cloth core carpet tape, then cut around it. Then hang if on the roller, with it in the closed position, then close the door against it, and it will stick to the door in just the right place without measuring anything.
Link to Latch
