Subject: Re: aluminum slatwall inserts
8/4/16
Eric Smith
Who are good suppliers for the aluminum inserts for slatwall? We want to run the panels on the cnc and put the inserts in afterwards. Need a matching bit also.
8/4/16       #2: aluminum slatwall inserts ...
pat gilbert
Depends on where you are at, I use Spacewall in Placentia Calif, they are also in Seattle, Georgia, Texas. I think they will sell the extrusions.
You should run the numbers on this though. They have a machine that gang cuts the slots which are diamond bits.
Spacewall
8/5/16       #3: aluminum slatwall inserts ...
james mcgrew Member
It really is easier and far better to just purchase what you want.
8/5/16       #4: aluminum slatwall inserts ...
Eric Smith
We do buy them when we need standard colors or finishes of slatwall.
This is where we need one or more sheets of a specific color - for example a job now is calling for 8 sheets with a specific Wilsonart metal laminate on the face. Are there suppliers in Northern California (we are in Sacramento) who will do that?
If not we do it ourselves so I figure better to get the panels laidup and run them on the cnc ourselves?
What do you experts think?
Thank you for the help!
8/5/16       #5: aluminum slatwall inserts ...
james mcgrew Member
I used US SLATWALL and was well pleased on a 70 sheet custom order
8/5/16       #6: aluminum slatwall inserts ...
Alan F.
I don't know if they make custom slat wall anymore but Capitol is local to you.
Last time we bought extrusion I think we bought 5 or 10 thousand feet. I forget the extruder but they were out of LA. The extruders are usually at IWF.
Capitol Store Fixtures
8/5/16       #7: aluminum slatwall inserts ...
Space wall does custom and they are fast. i would think you could find a local supper with quick turn around, it is the store fixture industry afterall.
8/5/16       #8: aluminum slatwall inserts ...
Far better off buying from a slatwall manufacturer. Be careful if you decide to make your own. Not all inserts are the same, some won't fit in the profile from a supplier. Make sure you get a matching diamond bit if you are going to do it. Typical carbide bits go down hill pretty fast because they run hot in the tight T slot. You can get the inserts already in the panel or not. Best to not if you are going to cut the panel up. You also need a saw blade made for aluminum. IE, neg. hook.
9/3/16       #9: aluminum slatwall inserts ...
Eric Smith
Thanks guys
    Doucet Machinery
