Subject: Re: Advice for sanding D shaped profile
7/18/18
Dave Edgerton  Member
We make chairs and stands and have to sand a d-shaped part either in the unassembled stage or afer the chair is assembled. we are talking many yards of this material.
We have been using orbitals to sand the roundover but perhaps a brush system would work better. Any advice?
I included a pic of a different chair but the task would be the same for the frame.
View higher quality, full size image (3120 X 3120)
7/19/18       #2: Advice for sanding D shaped profile ...
Pete
Look into a pump sander. A stationary one comes in handy for a profile like that. There are hand held ones as well.
7/19/18       #3: Advice for sanding D shaped profile ...
Pete D
Contact Flex-trim in NY. They work with Larick machinery and supply the abrasives as well as sell machines. There's a few different options depending on your requirements. If you're only looking to edge sand that roundover there's smaller machines that are specifically designed for that. You can send them a few samples and they'll run tests to figure out the best sanding sequence.
For finish sanding assembled pieces with profiles I use a surf prep 3x4 orbital with 1/2" foam abrasive. The foam abrasive conforms well to the profiles I use and it's a great substitute for finish sanding where hand sanding is the only option. I know QuickWood makes a handheld brush sander, the "F3", but I've never used it.
http://flex-trimusa.com/
8/3/18       #5: Advice for sanding D shaped profile ...
Max Neu
Look into the festool LS 130.
8/4/18       #6: Advice for sanding D shaped profile ...
Jay
quantities?
are you sanding thousands of feet/week? a couple hundred?
how are you milling this profile?
