Subject: Re: brandt edgebander error?
11/7/18
mike  Member
Website: http://www.lustigcabinets.com
brandt kd56 error 16; current overload error? any idea what I should be looking for to replace?
11/9/18       #2: brandt edgebander error? ...
Matt Krig Member
Open the middle door on the back and you'll see one dial type breaker turned horizontal while the others all face vertical. Turn it back up and it'll reset the breaker.
When we had those machines, it was usually caused by glue build up the the glue roller drive chain beneath the glue pot. If this is the case use a heat gun to soften the glue and pick it out carefully.
It could also be caused the feed drive being jammed or the gear motor being bad or overloaded or a number of other things, so keep a close eye on it after resetting the breaker.
11/11/18       #3: brandt edgebander error? ...
Wyatt
We got that error from not greasing the track frequently enough. It was giving the motor too much resistance. You might check that also after you reset the breaker.
8/27/20       #4: brandt edgebander error? ...
Paul Dunn
I have a overcurrent feed motor error and I lubed belt but do not know how to clear the errors so it will start up?
If anybody can help this it would much appreciated,
Paul
1/3/22       #5: brandt edgebander error? ...
Morvent
Reference point not ok.
3/27/23       #7: brandt edgebander error? ...
Cássio Vinicius Macedo Member
Website: http://www.cemacofficesolutions.com/
Good morning, did you manage to solve the problem with the reference point?
View higher quality, full size image (4000 X 1868)
https://youtu.be/tVln0cTglio
11/6/24       #12: brandt edgebander error? ...
Adam Nguyen
Brandt edgebander ( BRANDT OPTIMAT KDF 140) error: COM 2 STATION No. 1 M 0 read error 3. Any idea what i should looking for repair or replace. Thanks for any advice.
