Subject: Re: In-swing Clerestory - pole operated
3/4/19
MarkB Member
Have some small sash to build and a couple of these are high in a stairwell. In-swing (left/right swing not hopper style) and will be operated with a standard pole/hook from a 6-7 foot reach. Any latches I seem to find are spring loaded which I dont think is going to work with the inswing. Ive been looking for a latch similar to a standard double hung sash lock that would have a loop on it for the hook that we could mount centered on the swinging stile.
Im cautious of the spring loaded with the in-swing and having to compress the weather stripping and envisioning someone having to try to slam the sash closed due to the spring. I keep seeing the hook popping out of the latch, scratching the sash or breaking the glass and a few other pesky issues with the spring latch at the end of a pole and having to push the sash closed.
I considered going with the spring loaded and locating it in the upper corner where the spring pull would be vertical (pull down to unlatch/latch) but concerned the sash wont seal in the lower corner.
3/4/19       #2: In-swing Clerestory - pole operated ...
MarkB Member
Sorry all. Minutes after posting my message it dawned on my to search for "pole operated cam handle latch" and I found a solution that looks perfect from Truth hardware. Nice long lever handle with hole for the pole. Gave up too soon.
