Subject: Re: Front door
Front door
6/1/19
Joseph
Website: http://eultgenwoodworking.com
Any one put insulation between veneered panels on a front door?
6/3/19       #2: Front door ...
No.
Redundant.
6/5/19       #3: Front door ...
Stuart Douglas
In the shop I used to work at in Upstate NY we used to put blue foam between flat veneered panels when the profile and thickness allowed on exterior doors. It might have been negligible as far as R-value since the frame was always solid core, but we did it anyhow. It certainly kept the panels snug and allowed us to use thin stock or plywood instead of building up a honeycomb or developing a deep profile for the C+S. We also used Low-E sealed Glass whenever we could as well.
6/5/19       #4: Front door ...
Joseph
Thank you both very much for your input
6/5/19       #5: Front door ...
From side by side test done on insulated doors (I won't bore you with the details but I had my son do a science fair project) we found that regardless of how well insulated the door, weather strip is far more important. IR imaging showed that.
6/6/19       #6: Front door ...
I have a belief that one thick panel - 1-1/2" let's say, is better at resisting cracking than two 3/4" panels.
First - why does it crack? Bad glue - TBIII in particular, or bad joints, not fresh cuts, etc. Prevented movement will crack a panel it if is glued in a corner or two or three. It will crack when it shrinks. Or tries to. Bad wood - your fault. Extreme moisture changes - usually unfinished wood getting rained on, then finished the next day. Stored in a flooded basement for a month, etc.
I know that the TBIII failures would make for thin raised panels in pieces instead of one intact, but with a crack 75% of the way thru a glue joint on 1-1/2" panels. I know that if someone opts to strip the door, and they use some of the heavier solvents, the foam will melt partially or completely, making your phone ring.
And all this is now moot - at least for Acorn - since we have now adopted a 7-ply panel as our standard exterior panel. It is "plywood" of a sort, it does not move, and can even be glued in place. Solves all panel problems in one swoop.
    Doucet Machinery
