Subject: Re: Glazing Question
Glazing Question
9/15/19
Tom Norton
When installing insulated glass panels in a wood sash how much clearance should there be from the edge of the glass to the wood? I will be using 1/8" setting Blocks on the bottom.
Thanks!
9/16/19       #2: Glazing Question ...
MarkB Member
Ive always just left enough clearance so we dont introduce any shear on the IGU. 1/16-3/16 all the way around depending on the application.
9/16/19       #3: Glazing Question ...
Insulated glass manufacturers will tell you 1/8" minimum on each of four sides.
We no longer use setting blocks. We use an RTV sealant that effectively glues the glass to the wood, so there is no movement. We make divided light sash, so no large panes expanding and contracting.
We will order insulated glass 1/8" less than the opening. The key is to not 'squeeze' it in the opening as MarkB stated. If the two panes are not aligned correctly, then you are faced with a unit that is too large to fit. Then you either chisel, route, or hatchet the opening a bit larger.
9/17/19       #4: Glazing Question ...
Joe Calhoon  Member
We allow 1/8” all around, when measuring I use a 8mm block in the the corner to measure from as IG grows in size due to glass misalignment and sealant.
Blocking on single light openings is important to support both panes of glass. Swinging sash should be blocked at bottom hinge corner and top handle corner to to eliminate sagging of the sash. Double hung only needs blocking at the bottom.
Wet glaze with a caulking notch built into the tooling is the best method to seal the glass but requires some planning at the tooling stage and a skilled hand at the glazing install.
9/18/19       #5: Glazing Question ...
Tom Norton
Another question if I may.
When applying the interior stops is it advisable to run a bead of caulk/sealant underneath the stop?
9/20/19       #6: Glazing Question ...
Yep. This has both technical and aesthetic reasoning.
Technically, the glass unit is sealed off from the environment. This will help add life to the seals and slow down the chance of fogging.
Aesthetically, the sealant gives a uniform color between the glass and stop, and prevent fines from dripping or wicking between wood and glass. This, of course, is noticeable as one looks thru the glass unit towards the other side.
Using sealant that mimics the color of the finished door if dark, or is white or silver if painted light colors, will help make the insulating spacers disappear (they are also available in tones that will help them disappear). If done well, people will never notice the glass is insulated.
4/12/20       #7: Glazing Question ...
John Gulick Member
Website: http://jagulick.com
Many fabricators will cement glazing stops for aesthetic or sealing reasons, we never do. First, good luck trying to remove the stops for reglazing and the sealant joint will fail.
    Doucet Machinery
