Subject: Re: Wide Belt Sander Issues
10/14/19
John Member
I have an SCM Sandya 20. 3 heads, 120,150,180 sandpaper set up.
I run a lot of pine, cedar, redwood, and extira.
The pine and extira run fine through the machine, but when I run cedar and redwood through, it always gets stuck and leaves divots. I am taking .008 of material off at a time. The conveyor is clean and in good shape. running 16FPM.
Am i missing a setting? Do I need to adjust the rollers?
Any advice would be helpful.
10/14/19       #2: Wide Belt Sander Issues ...
Jared Emery
Could be oily wood losing traction on your conveyor. Try wiping the bottom of a cedar board with acetone right before you run it, wiped side down.
10/29/19       #3: Wide Belt Sander Issues ...
Adam West  Member
At a minimum I'd say that your hold downs or shoes might not be set right. The harder wood is giving a bit more back pressure which can stop the parts.
I would change out the 120 for a 100 grit in a heart beat. Make sure the 2nd head is removing 0.005" and the 3rd head is removing 0.002". If the 3rd head is a combi-head, take 0.002" on the drum and 0.001" on the platen.
Once you have this combo set up you can watch the parts moving through the shoes or rollers after the 1st head to be sure they are rolling and gripping.
If the conveyor is slick it can be dressed with an 80-40 grit on the front steel drum, but only if the machine is properly calibrated.
You can use a 5" random orbital sander with 120-100 grit. Let the sander rest on the table with not much pressure all the way around and then move over 1/2 the diameter and repeat. This will rough up the rubber a bit and make it more sticky with out the risk of grinding the conveyor at an angle.
Shoot me a pm if you would like to talk about it. I work on wide belts for SurfPrep sanding for a living.
