Subject: Re: Which is the best woodworking software program?
10/16/19
Frank K. Solomon  Member
Hello friends,
I am looking for suggestions on a user-friendly software program for woodworking.
Regards,
Frank
10/16/19       #2: Which is the best woodworking softw ...
james e mcgrew  Member
Woodwork or Cabinetry, I use Vcarvepro and aspire for most cad work to CNC and Moziak for Cabinets
10/16/19       #3: Which is the best woodworking softw ...
What is the best tool in your shop? Your favorite bone? Best Music?
Meaningless questions. Slightly more meaningful questions follow:
Are you designing?
Are you drafting?
Are you estimating?
Are you specifying?
Are you communicating with other design professionals?
Are you designing production?
Are you selling?
Are you tracking inventory?
Are you bookkeeping?
Are you chasing bad debt?
Are you asking questions on a public forum?
10/16/19       #4: Which is the best woodworking softw ...
MarkB Member
I think most of David's mentions are valid to an extent. A ton depends on what your doing. If your a small one man shop doing one-of's and only drawing for your own needs the options will be far different from someone (even a one man shop) that needs to provide drawings to customers, feed drawings to the shop floor, or generate files for CNC.
More info would be necessary. That said, the archives here are riddled with the same question even recently. Using the search feature can get you a ton of good information.
10/17/19       #5: Which is the best woodworking softw ...
Hiral Patel  Member
Website: http://www.hitechcaddservices.com
There are many woodworking software is in the top list like Solid works, Autodesk inventor, AutoCAD, Sketchup pro. But Autodesk inventor being the most adopted by the furniture designers because it is convenient and delivers 3D rendering images.
There are also many benefits of using Autodesk Inventor:
- It is flexible and versatile
- Additional woodworking Plug-ins are available
- Generation of models and drawings automated (iLogic), etc.
and more..
I think the following article will help you to get more information.
Inventor benefits to woodworking ind.
10/17/19       #6: Which is the best woodworking softw ...
pat gilbert
FWIW
The most popular is Cabinet Visioin for residential work
The most popular is Microvellum for commercial work
Others are KCDW, Keytrix, Cabmaker, Mozaik, et.al.
It depends on what you do
10/18/19       #7: Which is the best woodworking softw ...
cabinetmaker
we use cabinetvision for both residential and commercial
we also have a corian shop we use it for that and a plam top shop use it for that too
12/8/19       #8: Which is the best woodworking softw ...
Dave Edgerton  Member
I like mozaik. works with sketchup and makes cutlists. quite economical for a good program.
8/8/21       #9: Which is the best woodworking softw ...
Hannah Member
Website: http://camcad.com
I found a good read here maybe this can help https://camcad.com/news/cad/woodworking-design-software/
Woodworking Software in 2021
2/3/23       #10: Which is the best woodworking softw ...
Chaitanya Patel  Member
Website: https://www.truecadd.com/
There are a lot of great woodworking software programs out there, but my personal favorite is Autodesk inventor.
Inventor makes the design process for wood furniture simpler and more powerful whether it is for cabinet design or joinery design.
- In addition to 3D CAD models, the software generates BoMs, cut sheets, and other documentation for manufacturing and installation.
- This software allows for easy changes in dimensions and sketches, making drawing process more powerful.
- With it, you are able to export dimensional parameters and component quantities as well as specific descriptions for the creation of drawings straight away.
3/8/24       #11: Which is the best woodworking softw ...
veromadrig Member
As a beginner crafty amigo is very easy to use, just snap parts together and as a Pro, you can find inspo on their gallery plus it's free. It also gives you the list of parts with real measurements.
Free Woodworking Software recommendation
5/17/24       #12: Which is the best woodworking softw ...
Angy
Website: https://www.qecad.com/bim-modelling-services.php
There are numerous leading woodworking software programs, such as SolidWorks, Autodesk Inventor, AutoCAD, and SketchUp Pro.
5/17/24       #13: Which is the best woodworking softw ...
Angy - I believe the question was about which is the best. The OP, as well the rest of us, does not need another list.
I often wonder if these white bread miss type of responses are generated by a machine. People simply do not come up with things like Angy does,
    Doucet Machinery
