Subject: Re: Particle Board Core
Particle Board Core
2/24/20
Maybe just something new to me but was out looking at some auction equipment and in one shop they were laying up interior door rails and stiles with solid wood over 1" particle board? Of course commercial veneer doors over PB core I see all the time but I have honestly never seen like a 3/0-8/0 interior thick wood veneer raised or flat panel door over particle board before?
Only guy I talked to said they do it all the time.
2/24/20       #2: Particle Board Core ...
Could that be why they are no longer in business?
2/24/20       #3: Particle Board Core ...
David, That was what I knew your response was going to be ;-) and would have been my thought as well. But it was just surplus equipment. I found it extremely odd but had no idea.
2/24/20       #4: Particle Board Core ...
I am at the point where all I ever believed as rock solid in this craft is dissolving to less absolute, soft guidelines rather than rigid laws and rules.
Maybe 3/8" thick solid wood can act like solid wood, and maybe it can act like veneer. How much of one, or the other, and when and where it will work, or won't work, I do not yet know.
I do know the 3 and 5 ply mega panels in Europe have caused me to stop and think. These are sized to where they are building entire structures out of what most of us sitting here would call doomed panels.
How can it be? Should we let them know this will not work?
I personally have had no failures from thick wood being being used like veneer, only at 3/8" thick and seeing no problems. I also have never seen a problem with unbalanced laminations in door stiles and rails.
View higher quality, full size image (1024 X 593)
2/25/20       #5: Particle Board Core ...
John Member
The Germans have been using panels that some question for a long time - see link below. They usually do their homework.
John
Link
2/25/20       #6: Particle Board Core ...
TonyF
While the particle core may be just about profits, I wonder how much material scarcity plays into the picture. It is probably getting harder to find good quality solid lumber at a price point that allows for mass consumption. On its surface I don't like the idea, and yet I can not deny its omnipresence and seeming acceptance as the new millwork methodology.
In my first shop in the early 70's, a large lumber and millwork enterprise, I saw a six panel pine door, made by a major panel door manufacturer, where the panels had shrunk so much that there was a gap that you could see through between the edge of the panels and the door stiles. A rare case to be sure, but I wonder if similar episodes led to the advent of the "engineered door".
Flooring has become much the same. I would think that major companies have invested heavily in the R&D of such undertakings, and perhaps are more informed about the durability of such construction processes than guys like me, who are just shade tree mechanics in an engineered world.
TonyF
2/25/20       #7: Particle Board Core ...
dan summerhill Member
We work with PB core doors all the time. They are actually pretty good. Merrill Lynch
uses all 3/0x8/0 doors and PB gets used whenever they don't have a rating. They use a low density core which I think is the key.
