Subject: Re: Exterior grade MDF, or options?
3/13/20
Peter Gagliardi Member
So, this year has started as a busy year in doors for us. We normally do 15-20 doors along with the other millwork in the shop.
We have a current door order that will be an exterior slab- smooth both faces, and 2 1/2" thick. I have the frame and core worked out, but admit to not having much experience with the MDF type sheet goods. I only use it for one-off light use patterns. All our sheet goods are quality V/C interior plywoods.
I know of Extira, and thought I could get 1/4" skins for this door, but 1/2" is as thin as offered by them.
My normal supplier only offered an MR type MDF product which will not work as it is only rated interior.
So, does anyone have knowledge of, or experience with another smooth faced skin that is exterior rated ideally in 1/4" or so thickness?
Thanks in advance.
3/14/20       #2: Exterior grade MDF, or options? ...
MarkB Member
Seeing as your already in the MDF consideration why not look into James hardie smooth panels. Cant.get much more stable than that as long as you can lock/weep the moisture out of the bottom. There is another product called equitone or something like that that's a smooth exterior panel as well.
3/14/20       #3: Exterior grade MDF, or options? ...
Do any of the exterior MDF companies rate coefficient of expansion? I'd still be worried about humidity differences and expansion rates. Medite exterior says .4% width and length, but 15% on thickness. I'm having an issue figuring out the chart, so I can't swear to those numbers in your application. I'm not sure you could stress hard enough about the painting schedule for end grain. Painters are not the best at taking the door off and painting the bottom.
3/14/20       #4: Exterior grade MDF, or options? ...
The big manufacturers use an exterior rated hdf. It’s like Masonite except they use exterior rated resin. It’s typically 3-4mm.
I don’t know where to purchase it.
3/15/20       #5: Exterior grade MDF, or options? ...
Allen Chalifoux
Have you tried Bosie Cascade?
3/15/20       #6: Exterior grade MDF, or options? ...
Gary
Try looking at Tricoya. Made by the same makers of Accoya. Available in 1/4" thickness. The molecules in it reject any moisture.
3/16/20       #7: Exterior grade MDF, or options? ...
Thanks for the responses, the Tricoya looks promising if 1/4" is available.
3/19/20       #8: Exterior grade MDF, or options? ...
Marty Member
As suggested go the Tricoya
