Subject: Re: White Oak Top
White Oak Top
10/19/20
Fred
Website: http://rivercity.ca
we supplied a white oak top several months ago. it was laminated from strips of flat sawn white oak, flipped on edge to create a vertical grain, quarter sawn appearance. the top is 1- 1/2 inches thick, out of kd wood, finished with food grade oil. small checks have appeared in the rays only. some are so small that they are hard to see without glasses, But they can be felt by touch. we generally don't do these kinds of tops from white oak and use maple instead. I would just like to know if anyone else has had a similar experience with white oak. we have already decided to replace the top with a maple top. So I am just trying to find out if we should avoid using white oak for this in the future. Thanks in advance for your comments, fred
10/20/20       #2: White Oak Top ...
8/4 White Oak (guessing on the thickness....) is difficult to dry = expensive. It takes time to do it right. If it is rushed - not given enough time - it tends to develop checking in the rays. The smaller of these will often not show up until after fabrication or finish.
I would politely ask the lumber vendor to come pay a visit and explain why this is. Look at your leftover scrap and see if any checking is visible in those parts. Have them there for him to examine. If necessary, take him to the jobsite so he can see it up close and personal.
10/20/20       #3: White Oak Top ...
rich c
Most of those ray checks are started before going into the kiln. Hot weather and low humidity does that to wet white oak.
https://www.woodweb.com/cgi-bin/forums/furniture.pl?read=747340
10/20/20       #4: White Oak Top ...
Fred
Hi David,
Thank you for your info on this, we never had this experience before. We laminated this top around 6 months ago from 8/4 stock. We will save the top after the swap.
Our sales rep. always visits before X-mas, so there is a good opportunity for him to see it close up. They are a whole seller distributor and we are normally very satisfied with there wood. It will be interesting to hear his take on this problem. My lesson from this is maybe on the next order of heavy clear white oak is to cut a few boards to expose the rays and dry them a bid down in an oven to see if the rays check. Not sure if the is a good practice but I see if I can find any possible leftovers of that lift in our inventory and try it with them.
    Doucet Machinery
