Subject: Re: minimum dimension for roundwood structural timber
1/30/21
Steven Member
assistance sought from experienced individuals as to the feasibility of utilizing site-grown lumber as structural members in a guest house. Young post oak and water oak are available. Is 5" diameter at chest height sufficient for load-bearing vertical frame members up to 16'? The only tables found are for milled dimensional lumber.
1/31/21       #2: minimum dimension for roundwood str ...
We have a couple of old timberframing books that call out all the detailed engineering for timbers. Good for reference but without an engineers stamp none of it carries much weight.
The forestry forum has a log beam calculator that would likely give you some idea with round and sawn logs/timbers.
The grading is the kicker if your doing something that will require a stamp or any liablity.
Log Beam Calculator
1/31/21       #3: minimum dimension for roundwood str ...
Steven Member
Thanks Mark B. I'm thinking the client may have to be satisfied with largely decorative uses, but I'll check those sources.
2/17/21       #4: minimum dimension for roundwood str ...
akinator
Website: https://akinator.io/
We own a James Taylor 80 segment clasp transporter and this is authorized in Sri Lanka. We needed to change Hydraulic oil on this machine, and the machine manual says to utilize Mobil DTE 24 water driven oil or equalent. What occurs in the event that we use Mobil DTE 24 Ultra rather than DTE 24?
