Subject: Re: Curved benches
Curved benches
2/16/21
Michael Folan Member
Hi everybody
We landed this job of 100 linear meters of curved oak benches. It calls for 12 -15mm thick x 200mm wide pieces. Would you steam bend entirely or laminate and bend.
Thanks in advance
Mick
View higher quality, full size image (1080 X 2220)
2/16/21       #2: Curved benches ...
steaming bending an 1/2" x 8"(200mm) wide piece of oak in 3 bends as drawn would be a challenge with one piece. Impossible to replicate over 100m. Let alone 4 individual pieces.
This would definitely be a lamination job with a press. We would vac bag numerous ones side by side. It's a huge project . 500 pieces. whoa
2/16/21       #3: Curved benches ...
Michael Folan
Thanks a mill for swift reply. To compound matters theres a mixture of curved sections where each slat will need to be hand fitted after bending. In your experience will i need to source green lumber and how would i speed up the production with forms etc.
Mick
2/16/21       #4: Curved benches ...
You didn't figure this out before you bid it?
Is it indoor our outdoor?
2/16/21       #5: Curved benches ...
I would be searching for 2-3 mm veneers. Male and female forms in a big daylight press. I would imagine this would be ideally done with radio frequency curing but you will have to have a consult with an adhesives technical rep to ensure that the benches stay together
It would be worth the cost to buy a used press if you don't have one and probably the RF generator for the consistency and time savings.
2/16/21       #6: Curved benches ...
Michael Folan
Hi Bill
The benches are outdoor. We've been producing for years in european white oak with an oil finish. The vast majority are ex. 2" material. I figured in the price to include purchase of a RF generator as we have a heated daylight press. I also allowed in the costings to resaw 3mm veneers for bending. I'm meeting with a glue specialist and I'll mock up some samples and test before going into production. Thanks also Tom Gardiner for your input. I was thinking the same way.
2/16/21       #7: Curved benches ...
I believe an RF generator large enough to do that is in excess of $100K. I give you credit for taking that on.
2/16/21       #8: Curved benches ...
Massive job but I dont see it as all that bad if you opt for even shop sawn veneer layup. Never solids. Looks like a fun one.
2/16/21       #9: Curved benches ...
Can you produce shop sawn veneer at this price?
https://certainlywood.com/images-locator.php?item=1/10%20RF%20OAK%202011
4-6B
That's retail rift oak. I'm figuring you would see a substantial discount when ordering from a veneer mill the amount for this job. Core in seconds and faces AA matched. Or am I just lazy?
This will be a great challenge to work on. Good luck.
2/16/21       #10: Curved benches ...
This path was first tread by Charles and Ray Eames about 90 years ago. Resorcinol glue, male and female forms and RF generators.
Wait, is that smoke I smell?
2/16/21       #11: Curved benches ...
I was on the same trajectory as David without the RF but youd have to have the time to leave them in the forms. In todays world you could cut a set of forms to clamp those parts, perhaps double sided, (two clamped at once) and ditch the RF, ditch the bag, and go on.
2/16/21       #12: Curved benches ...
rich c
I'm with Bill. How did you land the job and not have a system ready to build it? Maybe that's why you got the job, you were the low bidder.
2/16/21       #13: Curved benches ...
BH Davis  Member
To me this seems like a good opportunity to at least check into the use of compressed wood. Given the volume of work and equipment investment the compressed wood might be both a better cost and labor option.
Below is one source. Do a search for "compressed wood bending" for other options.
Compwood
2/16/21       #14: Curved benches ...
Michael,
We have done tons of similar work. Never in any quanity of that sort. Maybe 10-20 ft jobs a mix of regular chair types as drawn. As well as a couple of jobs like your tapered/scribed chairs that go in a curve.
Those parts are time consuming, with test pieces. Typically the first mold needs a fair amount of work and rework to get the exact finished product. Its more like building fiberglass boat molds than traditional woodworking.
Personally, I would have spent a day making one myself using the vac bag technique, just to see if its an acceptable product. If its good then figure out a mass production model using a press or a big vac bag form 20 at a time ( 25 layups). You would need a skilled crew dedicated to this process.
The metaphor would be somebody walking in asking me to build (500) basic curved door jambs which is the simplest version of your design. I have built probably built that many jambs in my entire 30 year career.
Quoting a project like that without doing some extensive testing and maybe not enough experience especially with the qty is not wise.
The financial risk vs reward of that project is scary simple because of the quantity. You guess 4hrs per part except it takes 5hrs. 1hr x 500 units = 500 hrs x $100 shop rate = $50000
That's if it goes reasonable with a big buffer. The whole project could go sideways and then the math is scary.
2/17/21       #15: Curved benches ...
Michael Folan
Thanks Adam
Because of the scale of the job both the corten steel and stainless framing will be manufactured simultaneously in separate shops and come together at the end. We will both use prepared .dxf files so as on previous jobs the fit will be perfect. The cnc time to produce forms wouldn't be a problem.
I think ill stay away from Compwood for now as I'm certain we can get over the line with more traditional ways. Thx BH Davis.
As for the financial side of things the story is we priced this a year ago at the start of Covid. Then things went quiet in Ireland but is now full steam ahead playing catch up. It was all or nothing at the time. The full contract also includes 350 meters of our usual straight work in a mixture of Oak and Cumaru so rather than let the handy one go I took the lot. No matter what I'm covered.
Thx
Mick
2/17/21       #16: Curved benches ...
Alan F.
Ideally you can flatten out the parts or Slice it in 3-5 axis software so you can CNC the shape of the "pie" slices that are bigger on one side than the other rather than all the hand fitting, you still may need to trim them in but if spring back and elongation are consistent you might be able to create the shape, we have done that with veneer, never with solid, then forms.
A-
2/18/21       #17: Curved benches ...
michael,
Please post how this job turns out for you. I'll be interested in your fabrication methods. Good luck and I hope it goes well. Cheers
2/18/21       #18: Curved benches ...
Michael Folan
Good call Alan F on flattening the parts leaving minimal shaping afterwards. Any help on reducing distortion greatly appreciated.
Thx Adam I'll update this thread with progress pics
2/20/21       #19: Curved benches ...
Dave Edgerton  Member
I agree with the posts. If it were me I would make up a hot press form and use plastic resin adhesive. I had at one time done 2 km of bent handrail and that's what we did. A bit of setup but a guy could weld up a frame for a press pretty quick and use a firehose for the pressing pressure. You would have to keep the metal plates hot perhaps even manually when the press is open but that would work. The problem with vac bag is the cycle time though that would be ideal way to go. Perhaps a big enough setup to do 10 at a time. Heat is critical to speed up cycle time. What a fantastic project!
2/20/21       #20: Curved benches ...
You can use IR heaters and fants to cool and get a 40 minute cycle time in a Vacc press.
2/21/21       #21: Curved benches ...
Michael Folan
IR heaters sound good too. Can you expand more on your idea? Any links to specific heaters?
Thx
Mick
2/21/21       #22: Curved benches ...
Heated platens and IR heaters are okay for veneering onto a core but here you will need to heat through 15mm so the cycle times will be long with only the surfaces being heated. This is where RF gluing shines. Ex Factory sold the perfect daylight RF press recently for $26k. A bit bitch to ship to Ireland though.
2/24/21       #23: Curved benches ...
Keith Newton
If I were doing this, I would be using veneers wide enough to get multiples cut after the cure. The veneer stack after the thickened epoxy was applied would go into the bag which is laid over the form, (not in the bag). A stiff platen clamped down on the top before the front and back is eased on down and clamped under platens, then ready to pull the vacuum.
When the form is not inside the bag, the form can be cheap and easily banged together. It only has to be strong enough to not collapse under the force to bend the slippery stack of veneers.
A tarp with a few insulation sheets can quickly turn any available space into a hot room to speed the epoxy cure with a space heater blowing into it.
Finally a jig to cut the front to back taper is merely a box with a door opening the same size as the diagonal front to back dimension. Then using a circular jamb saw like the flooring guys use, can then saw up one side, around the curve, across the top, then on around and down, indexing off the flat side of the jig/ fixture.
After the first cut on the end, the second cut becomes the first cut of the next piece just by pivoting the jig back and forth.
If your shop already has a CNC that uses a big vacuum pump, all you need to do is tap into the plumbing with a manifold for however many hoses and fixtures you want to gear up for.
2/24/21       #24: Curved benches ...
We use IR to laminate through 9mm pretty easily. It might add some time to go deeper but it will still shorten the cure time.
Industrial Heaters
2/27/21       #25: Curved benches ...
Jeff
Like others, I think these questions and ideas should have been hashed over before you ever bid the job.
Lots of amazing help and ideas from everyone, but not much of a game plan before the game quite often ends up being a bad game, or in simpler terms lots of lost $$$$.
All the best.
1/30/24       #26: Curved benches ...
Robert
Can anyone recommend a publication that would serve as an RF "bible" so to speak. Any recommendations/suggestions greatly appreciated.
1/31/24       #27: Curved benches ...
BH Davis  Member
Fun to see this post come back to life. I'm sure everyone who participated in the discussion would like to hear how the project turned out.
I don't know of any RF drying guide but do a search for Workrite RF glue dryer and see what turns up. Also at IWF about 10 years ago someone was displaying a large RF dryer that could do something on the order of 4' diameter half round jambs.
The manuals for these machines would likely give useful information on techniques.
    Doucet Machinery
