Subject: Re: Cedar post end grain sealer??
3/1/21
Tom Norton
I have a job coming up to replace a cedar railing,on a deck, that had developed a nice case of rot. The architect has designed a new railing that incorporates a Trex aluminum railing system along with new cedar posts. The posts are notched on go through the deck and are bolted to the framing. I am thinking of holding the bottom off the deck by 1/4". But want to seal this end grain. I was thinking of West System epoxy. But am open to suggestions.
Thanks!
3/1/21       #2: Cedar post end grain sealer?? ...
Keith Newton
Hey Tom, I’m not sure exactly how you describe the project, but I’ve been using CPES on most of the restoration work that is exposed to the elements, even when using woods with high resistance to decay like Spanish Cedar. It really penetrates well into the end grain of softwoods, and will keep it from absorbing moisture. Even though the cost of material is pretty high, it will make the finish that goes on over it last better. I haven’t used the West brand for many years, but most clear epoxy does not fare well if not protected from UV. While the CPES is clear, it gets protested by being inside.
Smth and Company - CPES
3/1/21       #3: Cedar post end grain sealer?? ...
Tom Norton
Keith, Thanks for the reply. The areas that I was thinking about coating with epoxy would not be subject to UV. So maybe epoxy would be a good choice.
3/1/21       #4: Cedar post end grain sealer?? ...
Matt Calnen
I use the West System for all of my exterior work. On cedar it has two major advantages, one is end grain will drink it up, soaking up into the wood. The other is because it soaks it up, when the epoxy hardens, to makes a soft wood like cedar a lot harder. Because it is inside the wood, UV degradation is not an issue. What are you finishing the posts with? If you were to leave the posts unfinished, any residual left on the surface will whiten and fail if left exposed to sunlight. A UV protective finish will fix that problem.
3/2/21       #5: Cedar post end grain sealer?? ...
You don’t need any special penetrating epoxy. Any of the standard viscosity epoxies like West, System3, or MAS will work fine.
I’ve got a red meranti picnic table that I built for my wife in 2005. It’s a piece of furniture made from 2 x 4’s. It has sat in the dirt/lawn in Connecticut for the last 15 years. I masked the feet up about 1/2”. 3 coats of West System. I put a coat of Penofin on it once a year for the first 5. The last 10 years it’s weathered.
I just had a look. The very edges of the feet are a bit ragged. You could clean them up with a 1/4” round over bit. No rot. The film of epoxy is still there.
It says a lot about the rot resistance of red meranti(hard). The first coat of West always gets sucked up like water by end grain.
It’s nice to see something you’ve built last for a long time.
3/9/21       #6: Cedar post end grain sealer?? ...
Donald D Thibodaux Member
I agree with Keith with Smith's CPES. I discovered it over 30 years ago. The contractor was using it to treat exposed mortice and tenon on timberframed greenhouses. Working on sailboats, we treat everything with it, even repairs and holes drilled in wooden masts. On residential work, we soak the end of posts, railings and spindles before installations. All my custom exterior doors get treated at last fitting. It never has to be treated again and it glues down the paint. The problem with epoxy is it is at the mercy of wood movement and will crack and flake. CPES becomes part of the wood and will never flake, crack or peel. Here are a couple of davit boxes that are always outside, a porch remodel and one of the masts. Who wants to do this paint job every couple of years when you can make it last ten. I highly recommend this to anyone working on exterior wood projects. If you have questions, the owner of the company will answer them if you call. (Check out their Oak & Teak glue)
View larger image
View higher quality, full size image (605 X 454)
View higher quality, full size image (410 X 307)
Smith's Multiwoodprime CPES
