Subject: Re: Torrified Wood Opinions?
3/30/21
Website: http://dave@acornwoodworks.com
[Spell Check wants "Terrified" or "Horrified"]
I have some torrified Poplar that I glued up. Seems to have a bit of loss in glue strength.
Has anyone worked with it enough to be able to answer questions about it?
Does it Glue well?
Does it machine OK?
What - if anything - can be considered 'wrong' about it?
3/30/21       #2: Torrified Wood Opinions? ...
New to me
torrefied wood
3/30/21       #3: Torrified Wood Opinions? ...
Matt Calnen
About 12 years ago I did a basement bar for a homeowner with what my lumber dealer called “scorched” maple. It was a nice dark brown all the way through. I assume it is what you are calling Torrified.
It did “feel” alittle different, but never had an issue with it. Milled fine. It wasn’t a big mover for the lumber dealer so I never saw it again. I was able to look at the bar a couple years later and it was still in good shape.
3/30/21       #4: Torrified Wood Opinions? ...
I have worked with torrified (thermally modified) ash, red oak and poplar. The oak and poplar were for exterior use. I used urethane glue for the oak job about ten years ago. I haven't had a call about it but have not been back to see it.
The poplar I used for an exterior yurt door and it has been through an Alberta winter. Again no call back. No news is good news. I used Type 2 pva for it and other roasted ash glue ups. Machining and gluing is as normal. My supplier warns of loss of strength which I take being less flexible/more brittle. I have finished with oils and solvent lacquer with no issues. In fact the colour enhancement is beautiful.
My understanding is that seasonal movement is a tenth of untreated specie.
Early attempts in Canada with red oak were prone to honeycomb and severely brittle wood. It is not widely available now. You can order the torrification to a greater or lesser amount based on the desired colour change.
If exterior use then expect the same tendency for the wood to grey if exposed to the elements.
4/17/21       #5: Torrified Wood Opinions? ...
Rob Scaffe  Member
I serviced some molders at a company in Pa some years ago. I think maybe Bingaman.
It machined well through the molders.
I have a local friend that has a millwork company who uses a good bit of it. He mentioned to me that he found polyurethane glue (he used gorilla glue) worked best on it.
4/28/21       #6: Torrified Wood Opinions? ...
So David... I am curious about your experience with the torrified wood. Were you horrified or was it terrific?
4/30/21       #7: Torrified Wood Opinions? ...
I was terrified, then horrified. Ended up petrified.
"Smokes like a chimney, drinks like a fish..."
John Prine
    Doucet Machinery
