Subject: Re: Attaching Blocking
Attaching Blocking
6/8/21
Daniel Member
I am looking for more efficient ways to attach solid blocking on top and bottom of a 1-3/4" thick Particle board core. We need a block min.3-1/4" x 35 x 1-3/4" on each end of 75" long core. I've drilled, glued and screwed but left with holes to plug. I need to do hundreds at a time and be able to calibrate flush to attach a face veneer. Any thoughts?
6/9/21       #2: Attaching Blocking ...
I read this a couple times and I am having trouble following what you are trying to do. Maybe a drawing would help.
6/9/21       #3: Attaching Blocking ...
Mark B
Horizontal boring machine, dowels, and a hydraulic or pneumatic cylinder clamp?
6/9/21       #4: Attaching Blocking ...
Hen Bob Member
MarkB is on the right track. Do you have a Beam Saw? You could dowel and glue oversize and trim to final dimension, then veneer
