Subject: Re: flood damaged walnut moldings
10/13/21
jacob Member
Hi all!
I unfortunately had a bad flood situation in my shop- hurricane Ida.
4 feet of water from river etc. Most of my shop destroyed. However i salvaged a lot of solid walnut [ unfinished] .
Most ok, but some have black marks - from mud and water.
Can anyone advise me please how - if possible- to remove these?
I appreciate this.
10/18/21       #2: flood damaged walnut moldings ...
The Cajun Craftsman Member
The stains are probably just on the surface. We've experienced two floods in 2016 and just stickered the lumber and let it dry. It's not like green lumber that takes months. Make sure you have good air circulation on the stack.
10/19/21       #3: flood damaged walnut moldings ...
Keith Newton
I would try oxyalic acid on the black, which works to remove the reaction of tannic acid and steel on oak floors.
4/25/22       #4: flood damaged walnut moldings ...
jacpb Member
thank you
the acid worked like a charm
